I would like to get in Dynamo the geometry of objects included in an xref of my drawing, would it be possible?
Thanks for your help
Depending what you need, the node āSelect Model Elementā connected to āGet Element Geometryā will work⦠But if you look at the BiMorph package you will find more sophisticated nodes which might help
Cheers,
Mark
Thanks for your answer but i dont have any Select model Element node (iām working with Dynamo for Civil 3D) ā¦
The block name input should be the actual name of the XREF, not the layer that it is on. So in this case, it looks like the name is āBatiā.
Thanks a lot! Iām such a newbeeā¦
Now more difficult maybe : would it be possible to filter the objects of my XREF among their layer in the wref?
Thanks a lot @zachri.jensen iām starting with dynamo and i hope that one day i wiil be able to help people like you did.
@bertrand.savarit you are welcome!
