Get User Email ID
Hello all,
Has anyone used something which enables dynamo to get user email id to track usage?
You can build a view extension that utilizes the authentication method which Dynamo leverages to get to the Autodesk log-in info as of Dynamo 2.16 if memory serves. The specifics of such aren’t easy though.
Most I know use the windows username instead.
I got to the windows username using os module.
I believe this property might work:
@GavinCrump Thanks. Unfortunately for C3D doesn’t have the method defined in its Autodesk.Civil Namespace
This may be of use: dynamoPython/dynamoAPI/dynamologger.py at master · Amoursol/dynamoPython · GitHub
The authentication toolset which work in any Dynamo build is here: Dynamo/src/DynamoCore/Core/IDSDKManager.cs at ed5376f97a9ba108bb716efe02e61a8153c5a0e6 · DynamoDS/Dynamo · GitHub
You’ll have to use this as a source for your own tool as there are private APIs which can’t be called externally.
