Get Topography subregion curves sketch lines
How to Get Topography subregion curves sketch lines?
I know how to create subregion with sketch lines but not getting the sketch lines from an existing subregion in a project.
Any idea?
This appears to be the API methods used to get the boundaries. Will need some Python I think - haven’t seen any custom nodes that do this before.
Get subregion ids from a toposurface:
https://www.revitapidocs.com/2022/e491ee31-108d-a79a-267e-2fe01a0d5065.htm
Get subregion boundaries:
https://www.revitapidocs.com/2022/44b8d6bc-8903-1a37-f5a4-53b239d744d8.htm
The mepover and springnodes packages have some good examples of how to convert curveloops to protogeometry in Dynamo.
Hope that helps.
Hi @ruben.romero …could something here help…
that node Collect.elementSketch of Springs nodes package does the job, but I would have to create polycurve with that bunch of lines afterwards, and they must be sorted to be able to execute that task of closing a polycurve, thanks.
think you just can use polycurve by joined curves
sometimes the output is weird when joining lines by points, hopefully it works, I will try to see what the node does, thanks
I dont talk about polycurves by point i would use polycurve by joined curves and it will work becourse subregion is always a closed boundery so no need for sorting the curves…good luck :wink:
hello, I tried that node, although the output of lines are those that are cutting/slicing the original topography, but nothing about subregions.
Hi Ruben…not sure what your mean, think it works for me…
ruben.dyn (10.0 KB)
