Get the Z distance between 2 objects: a 2 point generic adaptive and a topography
Hi Can someone help with this:
I have made a 2 point adaptive generic models that intersect a topography, in order to get the Z direction from any building elevation to the topo. At the moment, I place the first adaptive point to say a corner of the parapet roof, the second adaptive point at below the topo. Then I move the second adaptive point manually so it intersect with the topo. Then I run the script to get the Z direction between point 1 and 2. See graph.
Is there an automatic way to move the second point to be snap in the topo ? or a way to measure the first point and its distance to the topo ?
Many thanks.
quick answer to your second question, check the OOTB geometry.distanceTo node Dynamo Dictionary
and to reply to your first question, dig into this:
or this
You can get the geometry of topo and then use Point.Project node to get point on topo.
Thanks Jean. Will take a look.
Thanks Deniz will take a look.
Thanks everyone. I was able to get this working, using Spring nodes Geometry.IndexByDistance.
Pretty sweat :slight_smile:
