Hey, I’ve been struggling to extract only the structure material of my elements. I might be close, but I can’t get the index of the material which is considered as structure. In the picture I want to get the “3” from the code block which is the index of the structure material.
You need to use the IsCore (Structure) to get the index which is 3 in this Case. Once you have that, use FilterByBooleanMask on the Material list, but don’t convert to Int like you show, just use True/False.
Also, I think for the “Functions” output you need to use Level 2 because it’s a sublist, but can tell for sure with what you’ve shown.
wall 1.dyn (13.9 KB)
