Get/Set Location of Schedule graphics follow up
Hi @Konrad_K_Sobon, thanks a lot for sharing !!
I am trying to do almost the same show on this topic Get/set location of schedule graphics on sheet but can’t find how I can get the location of the schedules already placed in my sheet, any idea ?
This should do the trick:
# Copyright(c) 2017, Konrad K Sobon
# @arch_laboratory, http://archi-lab.net
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
clr.AddReference("RevitAPI")
def process_list(_func, _list):
    return map(lambda x: process_list(_func, x) if type(x) == list else _func(x), _list)
def get_location(item):
    return UnwrapElement(item).Point.ToPoint()
output = []
try:
    errorReport = None
    output = process_list(get_location, IN[0])
except:
    import traceback
    errorReport = traceback.format_exc()
# Assign your output to the OUT variable
if errorReport is None:
    OUT = output
    OUT = errorReport
Please mark the answer as a solution if it answers your question.
It works ! Thanks @Konrad_K_Sobon
