Get Section Shape of Column/Element
Hi all, Hope you’re doing well !
I was wondering to get section shape of column elements in dynamo and if I use getparameter node I am getting the integer value of values. I want to extract the data of section shape of columns. I want to convert “31” to “Rectangle”. I even checked with element.parameter node there I am getting section shape as “Rectangle” but if I check the values of the parameter then I get “31” for all.
So is there any way to get that through python?
Here is the sample:
@shashank.baganeACM ,
what do you mean? as a string in a parameter ?
KR
Andreas
You’re looking for ParameterValueAsString. It’s an option in the API but a few custom node packages also have nodes that already do it.
@Draxl_Andreas I mean to say if I try to get the parameter value then I am getting Section shape parameter value as “31” not as Rectangle. I want it to get as rectangle.
@Nick_Boyts I have tried it but not getting this. The code follows as below
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
elem = UnwrapElement(IN[0])
elem_param = elem.LookupParameter("Section Shape")
paramvalue = elem_param.AsString()
OUT = elem_param.AsString()
Mepover has a node that gets parameter value as string, what do you get when you try that?
@pyXam I got the results:
The following is the final workflow:
clr.AddReference('RevitAPI')
if isinstance(IN[0], list):
	element = UnwrapElement(IN[0])
	element = [UnwrapElement(IN[0])]
name = IN[1]
prefix = IN[2]
listout = []
if prefix == False:
	formatOptions = FormatOptions()
	formatOptions.UseDefault = False
	formatOptions.UnitSymbol = UnitSymbolType.UST_NONE
def checkParameter(param):
	for p in param:
		internal = p.Definition
		if internal.BuiltInParameter != BuiltInParameter.INVALID:
			return p
	return param[0]
for e in element:
	param = e.GetParameters(name)
	if len(param) == 0:
		listout.append(None)
		p = checkParameter(param)
		if p.StorageType == StorageType.String:
			listout.append(p.AsString())
		elif p.StorageType == StorageType.ElementId:
			listout.append(p.AsValueString())
		elif p.StorageType == StorageType.Integer:
			if prefix == False:
				formatOptions.DisplayUnits = p.DisplayUnitType
				listout.append(p.AsValueString(formatOptions))
OUT = listout
