Get Section Geometry
In the Sample Line group, the section views were obtained 50 m wide from the alignment to the left and right.
The coordinates were obtained as Section Geometry, and when they were Curved, the coordinates were obtained.
Since the section view itself was acquired 50m wide to the left and right, I assumed that the x-coordinate would be -50 to 50, but for some reason I could not get all the points.
How can I get the x-coordinates from -50 to 50?
way2.dyn (185.0 KB)
way2.dwg (4.3 MB)
HI
I don’t understand Required
try
import System
clr.AddReference('AcMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.Civil.DatabaseServices.Styles import *
civdoc = CivilApplication.ActiveDocument
SS = IN[0]
def label(SS):
	global adoc
	global civdoc
	II = -1
	output = []
	if not isinstance(SS, list):
		SS = [SS]
	with adoc.LockDocument():
	    with adoc.Database as db:
				for c in SS:
					output.append(c.Location.Y  )
				t.Commit()
	return output
OUT =label(IN[0])
import System
SS = IN[0]
def label(SS):
	global adoc
	global civdoc
	II = -1
	output = []
		SS = [SS]
				for c in SS:
					output.append(c.Location.X  )
				t.Commit()
	return output
OUT =label(IN[0])
