Get pipes with certain direction
hi,
how can I get pipes with a certain direction of flow? Is this possible?
Can you please refer to what you have tried so far and/or to related posts such as this one?
this my code :
https://pastebin.com/AE5MkUC1
# Import RevitAPI
clr.AddReference("RevitAPI")
# библиотека динамо для работы с ревитом
# Использование библиотеки DSCoreNodes (основные ноды расположенные на вкладке библиотеки слева в разделе Core)
clr.AddReference("DSCoreNodes") # DSCoreNodes.dll лежит здесь C:\Program Files\Dynamo\Dynamo Core\1.3
import DSCore
clr.ImportExtensions(DSCore)
from DSCore import *
import itertools
#Назначьте вывод переменной OUT.
list_ps=[]
list_fs=[]
list_elbow=[]
list_tee=[]
list_z=[]
#filter pipes
list_ps=[i for i in IN[0] if i.GetCategory.Name=="Трубы"]
#filter pipes fittings
list_fs=[i for i in IN[0] if i.GetCategory.Name=="Соединительные детали трубопроводов"]
#get intersectioon fittings with pipes
for k in list_fs:
	for j in list_ps:
		if k.BoundingBox.Intersects(j.BoundingBox)==True:
			sublist= [k, j]
			list_z.append(sublist)
lst=sorted(list_z, key=lambda x: x[0] )
#Sort pipes from fittings
ps = dict()
for x in lst:
    p = x[0]
    if p in ps:
        ps[p].append(x[1])
        ps[p] = [x[1]]
result = sorted([v for k,v in ps.items()], key = lambda x: x[0])
# elbow and tee lists
#for i in result:
#    if i.Count==2:
#        list_elbow.append(i)
#    else:
#        list_tee.append(i)
OUT = result
Screenshot_19
and this simple pipes
im just get pipes which is connected to individual tee (later ill use many branches of pipes but now its just simle example)
and im want to get in different lists the pipes in green frame and red frame
may be use the degrees between pipes: 0 degress or 90 degress for example…
and better : if we now flow direction (how vectors orientation for example) then we can filter pipes with similar direction
and main : im want to do this in python (or used minimum count of code blocks)
This thread could interest you too:
@til.shviger It would help if you could upload a small Revit file with few pipes.
this rvt file
@Vikram_Subbaiah , are you haven’t found a solution for my question ?
@til.shviger I can foresee inadequacies in the example below, but hopefully it will help direct you
pipeDirection.dyn (9.3 KB)
20170925-2
@Vikram_Subbaiah
thank you!
Can you explain me how works the node Vector.Normalized? why we are use it?
Vector.Normalized gives us the corresponding unit vectors and enables comparison
The origin of all normalized vectors is the origin and magnitude is 1.
