Get Parameter via python?
How can i see my Parameter Names?:
elements = UnwrapElement(myDoors)
test = []
for i in elements:
    for j in i.Parameters:
	    test.append(j)
OUT = test
and how do i call a specific one like “Comments” and his values?
:)KR
Andreas
https://www.revitapidocs.com/2020/ce77c924-9e80-7668-cce8-c3be02b1d254.htm
You have to get the Definition and then get the Name
test = []
for element in elements:
    for parameter in element.Parameters:
        parameterName = parameter.Definition.Name
            test.append(parameterName)
   OUT = test
And if you want a specific one, do it like this:
test = []
    parameter = element.get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
    test.append(parameter)
   OUT = test
How’s the second example work? I just tried it and got
i got the same issue
Yes that is the Parameter API object for the Parameter “Comments”.
from there you can get the name of the parameter → “Comments” or the Value of the parameter of the storage type. If you want the name, follow my first example:
Get the name via Parameter → Definition → Name
name = parameter.Definition.Name
2021-01-28_16h23_31
no it worked
for getting this parameter i can index it or call? asString, toString
	test.append(parameterName.AsString())
    test1.append(parameter.AsString())
the reason is i also want call the values from the parameter “comments”! so the output should be strings
The AsString() methode behind the parameterName is a bit unnessecery since ParameterName is already a string
^This is the right way to get the value for the Comments parameter via the api
one pice of puzzle more !
I made this zip-loop - it works well! i want to make dictionary that keys and values match.
And when they the symbols got placed.
for i in zip(Types,sym):
    dic.append(i)
Can i say in the for-loop alredy which is Key and Value?
{ Key : Value, "Type" : "Comment", DetailComponent : Door}
if Comment "Gelb":
  place.Symbol"Gelb" to centerpoint of coresponding door
Thats the “psychoCode”
hmmmm
KR
Andreas
Easiest way would be to first create a dictionary with only keys:
types = ["Gelb","Blau","Rot"]
dictionary = dict()
for color in types:
    dictionary.add(color, [])
This will give you an dictionary with Blau, Gelb, Rot
The loop thru your elements with comments:
    parameter = get_Parameter(BuiltInParameter.ALL_MODEL_INSTANCE_COMMENTS)
    value = parameter.AsString()
    if dictionary.Keys.Contains(value):
        dictionary[value].append(element)
This will give you a dictionary with the elements sorted in yellow, red and blue
full code:
dictionary = dict()
for color in types:
need i any special library?
2021-02-01_15h58_34
how do i difine “add”?2021-02-01_15h59_34
add has to be Add (didn’t test the code before hand, just typing it off the top of my head)
But you need to import the dictionary from the System.Collections.Generic
After you can use “Add()”
I always use:
from "namespace" import * #to import everything in the namespace
2021-02-02_12h39_25
it still says i have an index error?
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
app = uiapp.Application
types = ["Blau","Gelb","Rot"]
myDoors = FilteredElementCollector(doc).
OfCategory(BuiltInCategory.OST_Doors).WhereElementIsNotElementType().ToElements()
Symbl = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_DetailComponents).WhereElementIsElementType().ToElements()
points =[]
test = []
dic = dict()
test.append(parameter.AsString())
for color in types:
dic.add(color, [])
if dic.Keys.Contains(value):
    dic[value].append(element)
for e in elements:
bb = e.get_BoundingBox(None)
	if not bb is None:
    	centre = bb.Min+(bb.Max-bb.Min)/2
    	points.append(centre.ToPoint())
for s in Symbl:
try:
	if types.Contains(s.Family.Name):
		output.append(s)
except:
	pass
OUT = test,dic
#Get Location points
He means `“namespace” as an infill :slight_smile:
Just use
and make sure you use Add() in stead of add().
is there any redundency?.. i think my libraries still not conform
2021-02-02_14h18_05
i got “new Errors!”
hello
  • there is an indentation problem at lines 60, 61, 62
  • element.get_Parameter(…) at line 52
Note:
avoid try… except:pass (unless you have no other solution)
As far as I know its GetParameterValue?
ElementID is the BuiltIn enum that was previously mentioned
Please read through some of the API. Also a quick search on the docs never hurt.
i use this coment severial times, it works fine!
when i delete my Dic-block. all workes fine
The 3rd for loop you are calling get_Parameter without element.
Make sure it says element.get_Parameter.
these are my pices right now.
one piece in python would be get view f.e. floor one
how can i get this together in the dictionary? In the dictionary there is still an errortest.dyn (5.6 KB)
KR
AndreasProjekt_.rvt (1.2 MB)
