Get parameter Value By Name returns empty list
I’m trying to Get the parameters values By name but I get an empty list (even though I have defined the following parameters “surface”;
“longueur”;
“pricing unit”;
“cost”;).
Does anyone have an idea about the reason behind this please?
Are they type parameters?
Yes they are
Then you need to get them from the FamilyType element.
Capitalization matters. Match character cases to the parameters. I believe that’s the issue? If you are calling those 4 parameters are they shared between those 3 categories? If not you will run into some null or empty lists.
The capitalisation was the reason why I got empty list.
Thank you so much for your help!
