hi,
Is there any way to do it for Civil3D dynamo? can you help me with the python code block
Thanks for help !!!
hi,
Thanks for help !!!
Here ya go!
clr.AddReference('AcDynamo')
from Autodesk.AutoCAD.DynamoApp import *
currentWorkspace = AcDynamoRuntime.DynamoModel.CurrentWorkspace
nodeNames = []
for i in currentWorkspace.Nodes:
nodeNames.append(i.Name)
OUT = nodeNames
Hi @zachri.jensen,
What a quick response!!! You are becoming my reference within the forum
I wonder if this can be done but only with nodes in a certain node group. For example, if there is a node group called Group1 that contains nodes node1_1 , node1_2 , node1_3
the script has to return only the node names within the Group1
Is there any way of doing this?
There’s always a way with enough time ![]()
I’m sure you can dig into the CurrentWorkspace class and find what you need for node groups. Sounds like good practice.
