If i need to get the middle point between two parallel curve and two curves have a different lengths
What is the best workflow to do that?
Hello @Mo-Samir …I think the best workflow is you show an image and share whatever you tried and then I’m sure you will get some help
ahh i see…looks like walls…here you have many options…i would go with Genius Loci "if i build walls "
he had nodes there support all layers , correct me if am wrong …
no,I need to create structural framing so I need the middle line.
Hello @Mo-Samir …share you dyn file
