i’m looking to get parameter values for rooms that are in link files. Those parameters are from a key schedule.
Any idea is more then welcome
Here’s a small sample: Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
check package bimorphNodes
I’m after the Key Name value from a link file
OOTB nodes work on the current document, but you can bust up the string representation of the parameters if you are only looking to get the value.
Similar solution (getting the string representation of the parameter value)
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import net library
from System import Array
from System.Collections.Generic import List, IList, Dictionary
def funcEval(elem):
return [elem.LookupParameter(para).AsValueString() for para in lstPara]
def recurseParaValue(lst, i = 0):
global funcEval
newlst = list(lst)[:]
if i < 20000: # prevent infinite loop
for idx, elem in enumerate(lst):
if is_iterable(elem) and len(elem) > 0:
newlst[idx] = recurseParaValue(lst[idx], i+1)
print(elem)
newlst[idx] = funcEval(lst[idx])
return newlst
is_iterable = lambda x : isinstance(x, list) or x.GetType().GetInterface("IEnumerable") is not None
toList = lambda x : x if is_iterable(x) else [x]
lstRoom = toList(UnwrapElement(IN[0]))
lstPara = toList(IN[1])
OUT = recurseParaValue(lstRoom)
