Get items located in rooms
I made this flow to get the room where each element is located in a specific parameter (ROOM), but when I run it, it shows the same room for all the elements and I’m not sure why this happens.
Check for unplaced Rooms and get rid of em
then try again
You’re also just doing a basic 1-to-1 intersect of the elements with the rooms. You’ll have to use list levels or cross-product lacing to check the intersection of every element with every room. There are also nodes for checking if points exist in a room that could help simplify this process.
Thank you very much, I am still learning but I have only been using Dynamo for a short time.
Just ask. We are here to help
Instead, you can use FamilyInstance.Room or FamilyInstance.Space
The intention I have is to send this information to Excel along with the coordinates and the ID; this is my basic flow to send everything to Excel. How can I also add the room to which each element belongs?
Elements posicion.dyn (168.2 KB)
