Get Geometry from Autodesk.Revit.DB.Line outputs for Crop Region
I’m trying to use the crop region of certain views to create detail lines for Key Plans. I was able to modify this code to process multiple views at once and return their boundaries:
However, the output is a list of "Autodesk.Revit.DB.Line"s as shown below:
I’ve tried to get the lines’ start points, end points, etc. but the output list of lines is the makeup of a CurveLoop, and I can’t discern how to call upon the lines composing the CurveLoop within the Python script. Here is the code:
clr.AddReference('RevitAPI')
views = UnwrapElement(IN[0])
curveloops = []
for view in views:
	crsms = view.GetCropRegionShapeManager()
	crshapes = crsms.GetCropShape()
	curveloops.append(crshapes)
OUT = curveloops
Maybe I am overlooking something obvious but I’m stumped! Would appreciate any ideas that may point me in the direction of retrieving these Lines’ geometry.
There is some Python script from the MEPover package that should do the trick.
Its a cool package with a few neat features :smiley:
# Import ToProtoType, ToRevitType geometry conversion extension methods
if isinstance(IN[0], list):
	view = UnwrapElement(IN[0])
	toggle = 0
view = [UnwrapElement(IN[0])]
toggle = 1
listout = []
for x in view:
region = x.GetCropRegionShapeManager().GetCropShape()
if len(region) > 0:
	lines = [y.ToProtoType() for y in region[0]]
	listout.append(lines)
	listout.append([])
if toggle == 0:
	OUT = listout
	OUT = lines
Thank you so much! That did the trick perfectly - I was thinking someone had to have had this figured out already but couldn’t find anything :smile:
Thank you very much every time i got stuck in this issue, and dont know what to do (ToProtoType())
The Same To me. :joy:Have you figured out this problem?
