Get element from faces
Hello
An approach with a filtering of surfaces with a dot product with Z vector
#import Revit API
from Autodesk.Revit.UI.Selection import *
outFaces = []
TaskDialog.Show("selection", "Select Faces")
refs = uidoc.Selection.PickObjects(ObjectType.Face, "select face")
for ref in  refs:
    elem = doc.GetElement(ref)
    face = elem.GetGeometryObjectFromReference(ref)
    bbxUv = face.GetBoundingBox()
    centerUv = (bbxUv.Max + bbxUv.Min) / 2
    normal = face.ComputeNormal(centerUv)
    normal = normal.Normalize()
    if abs(normal.DotProduct(XYZ.BasisZ)) < 0.5:
        surfaceDs = face.ToProtoType()
        outFaces.append([elem, surfaceDs[0], surfaceDs[0].Area])
OUT = outFaces
