Here’s a trick using Revit Lookup to find the coordinates of existing Views so you can use those points for placing Views on an other Sheet.
Revit Lookup - Snoop Current Selection:
Copy the GetBoxCenter
Paste into a code block like:
Point.ByCoordinates(1.82981431014265, 0.657879970631007, -0.5);
Make your list of Views the same count as the list of points. This graph shows placing five views on a Sheet:
or use the properties directly in dynamo…
Similar, but putting in the View center points doesn’t depend on other views existing. I’m using it to place new Views on a new Sheet.
Still very possible after initial placement via GetBoxCenter and SetBoxCenter
Nodes available in Steamnodes and Rhythm .
To be clear, I think showing RevitLookup is completely valid and a worthy example that user’s should familiarize themselves with.
