Get CAD Overlapped Polycurves
hello all,
I’m trying to get both the rectangles separately (polycurves) from the cad file. all objects are in one layer.
overlaped lines.dwg (67.5 KB)
try to group curves first. Use Group Curves node and see if it helps…
null
Connect _groupedCurves with the node PolyCurve.ByCurves, and see if that helps.
EDIT: use level @1 in Group Curves node
Hi keep in mind group curves expect a flatten list…
or try set level to L2 in group curves
@sovitek
did you try with overlapped lines?
nope, seems you have other issues as well…
but here is a rough way there probably could work on your unordered cad files
btw there are something wrong with you cadfiles you have uploaded i guees…
wow, thank you very much @sovitek
If someone is looking for the same, it’s here for reference.
during import Revit converts the curves into polylines when they are attached (which follow each other)
test import instaance
so here another solution with Python
import sys
import System
clr.AddReference('RevitAPI')
out = []
def get_CAD_polylines(importinstance, layer_Name=""):
    get import instance polylines and create closed polygons
    out = []
    opt = Options()
    geoSet = importinstance.get_Geometry(opt)
    for geo in geoSet:
        if isinstance(geo, GeometryInstance):
            for g in  geo.GetInstanceGeometry():
                if isinstance(g, DB.PolyLine):
                    gStyle = doc.GetElement(g.GraphicsStyleId)
                    gstyleName = gStyle.GraphicsStyleCategory.Name
                    if System.String.IsNullOrEmpty(layer_Name) or layer_Name == gstyleName:
                        ds_polygon = DS.Polygon.ByPoints([p.ToPoint() for p in g.GetCoordinates()])
                        out.append(ds_polygon)
    return out
importinstance = UnwrapElement(IN[0])
layerName = IN[1]
OUT = get_CAD_polylines(importinstance, layerName)
