@craig here is the python code.
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.EditorInput import *
# Import references from Civil3D
editor = adoc.Editor
with adoc.LockDocument():
with adoc.Database as db:
bt = t.GetObject(db.BlockTableId, OpenMode.ForWrite)
btr = t.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite)
blh = []
blr = []
errorReport = None
for oid in btr:
bl = t.GetObject(oid, OpenMode.ForRead)
try:
# Filter BlockReference starts with.
if isinstance(bl, BlockReference) and bl.Name.startswith(IN[0]):
# Get values of handle & Rotation.
blh.append(bl.Handle)
blr.append(bl.Rotation)
# Catch and report Exception...
except:
import traceback
t.Commit()
if errorReport == None:
OUT = blh,[x*57.2958 for x in blr]# Convert from radians to degrees
OUT = errorReport
Please mark the post as solved. You’re welcome!
