Get all elements in view and count Polygones(faces)
I try to find a solution to count polygones of Elements.
easiest way is just select all elements in a 3D-View. But i is timecosuming.
clr.AddReference('RevitAPI')
clr.AddReference('System')
element = UnwrapElement(IN[0])
#Get Elements of the FamilyInstance Class and by Built-In Category of StructuralFraming in Active View only...
elems = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(FamilyInstance).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsNotElementType().ToElements()
OUT = elems
Next way: how can i modifie my Elementcollector that he collects all elements in view?
I count by faces, is this correct? or is there a option poligons, meshes,… ?
I want to to do some prequality issues before i write a .ifc
KR
Andreas
i think it should work like this except some element cannot be converted in this way to geometry. you may try it
But i have to do it, one by one category. Ok Thank you
The filtered element collector you are using runs on the active view per this portion of your code FilteredElementCollector(doc, doc.ActiveView.Id). If you want it to run on another view, change doc.ActiveView.Id to a new input view’s id. So add a new line for the input of the view, something like targetView = UnwrapElement(IN[1])
and change the doc.ActiveView.Id to targetView.Id and see if that clears things up.
Element.Faces will get all the faces of most elements, reducing the compute load over what you would get from Element.Solids > Geometry.Explode. I am not sure if it will graph mesh faces or not so test that carefully.
a face can have several triangles, here is an example counting MeshTriangles on faces
currView = UnwrapElement(IN[0])
opt = Options()
elems = FilteredElementCollector(doc, currView.Id).OfClass(FamilyInstance).OfCategory(BuiltInCategory.OST_StructuralFraming).WhereElementIsNotElementType().ToElements()
total_triangles = []
for e in elems:
	typeId = e.GetTypeId()
	opt.View = currView
	geoSet = e.get_Geometry(opt)
	for g in geoSet:
		if isinstance(g, Solid) and g.Faces.Size > 0:
			nbrtriangle = sum([f.Triangulate().NumTriangles for f in g.Faces if f.Triangulate() is not None])
			total_triangles.append(nbrtriangle)
		elif isinstance(g, GeometryInstance):
			for instObj in g.SymbolGeometry:
				if isinstance(instObj, Solid) and instObj.Faces.Size > 0:
					nbrtriangle = sum([f.Triangulate().NumTriangles for f in instObj.Faces if f.Triangulate() is not None])
			pass
	geoSet.Dispose()
total_triangles = sum(total_triangles)
OUT = "{} MeshTriangles for {} Elements".format(total_triangles, elems.Count)
