Hello community,
I would like to share with you guys something that is happening to us and we cant find a reason for it:
We are checking the distance between two set of points using the node Geometry.DistanceTo
Why when we modify the input order in the node the minimum distance vary, THIS SHOULD NOT HAPPENED, as it is a minimum value of a cross product, any ideas?
Dyn attached
Geom to dist.dyn (25.0 KB)
