Hi everyone,
I am trying to get the host of a Generic Model Tag in Dynamo like it is also possible in Revit:
In Dynamo I try with different nodes but nothing works.
Thank you!
FamilyInstance.GetHost requires a FamilyInstance as input not a Tag.
I’d expect Tag.GetHost() works. Which package it belongs to?
Why not just use Select Model Element to pick the host element if you only have one target ? If you are look for a batch process, retrieving hosts from tags is also achievable by a bit coding.
Yes this is why I also tried to get a Familyinstance from the types but this also does not work.
Its from “Zhukoven”.
Thanks Awesome. That works!
I found out it also works with: Tag.TaggedElement
