Not without seeing the graph itself. The list of what it could be is longer than what could be typed.
It appears that curve.offset+ and scopeif+ were causing some issues. Building those functions via out of the box tools appears to have resolved things.
I have the same problem, one output has no value. What do I need to check?
Check if you are using any custom packages that might not be compatible with Dynamo Sandbox, like Bimorph Nodes, which relies on the Revit API. Make sure all necessary data is accessible in Generative Design. Also, ensure you have the latest Generative Design package in Dynamo Sandbox and add the appropriate paths from Revit.
I also faced some issues with nodes from Clockwork package. Explore your options to probably do some replacements.
Also, we sometimes skip thinking of simple solutions like these as well:
-Missing packages in the dependency folder.
-The use of some node which calls for Revit geometry.
-The Dynamo script is creating a null value somewhere in the loop due to a certain combination of parameters creating some errors.
