From the coordinates inside the blocks to the cogo points
Hello all
How can I get the coordinates inside the block?
Then cogo points created from it because the block is moving from its place, and its properties cannot be taken
Thanks in advance
xxx
AAAAA 010 010.dwg (961.2 KB)
Hi @hosneyalaa
Thank you so much @Kulkul
I have no experience split lists to CREATE a point
Is it possible to complete the solution?
Thank you
MTEST TO COGO POINTS.dyn (46.9 KB)
String.Split node using the “\” character as the splitter. This will pull the N apart from the E values giving you sublists.
String.Split again using the : character as the splitter. This will give you sublists in your sublists for the prefix and the value.
List.LastItem at Level2 keeping the levels (so @@L2) will give you the numbers, but they’ll still be strings. Convert them to numbers and you’ll just have to pull the indexes to create points.
Note that if your prefix has meaning (ie: the N changes to an S) you’ll have to add a few more steps.
You should try what @jacob.small has suggested above and come back here if you hit the wall.
@jacob.small @Kulkul
Hello, you have reached this stage, the next step
MTEST TO COGO POINTS 012.dyn (59.2 KB)
Welcome
How can I replace the Python Script file?
with nodes
To collect two lists to creating points
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
# Import Dynamo Geometry reference
dataEnteringNode = IN
editor = adoc.Editor
robots = IN[0]
colours = IN[1]
index = range(len(robots))
OUT = []
for i in index:
    #OUT.append("Ich bin " + robots[i] + " und " + colours[i])
    OUT.append(DS.Point.ByCoordinates(float(robots[i]),float(colours[i]),float(0)))
MTEST TO COGO POINTS 013 solution01 .dyn (97.6 KB)
