How can i cut the formwork surface for each element, both for the beam and the column?
Because when generating the joint of elements in a single solid, it is generated that way
here is a possible solution (not necessarily the most optimized one)
It will be necessary to remove the smallest faces of the beams opposite the surfaces of the columns
Cordially
christian.stan
Related topics
| Column formwork | 2 | 1272 | June 21, 2019 | |
| Dynamo column formwork | 6 | 533 | January 17, 2022 | |
Formwork Script - Contact Surfaces
4 | 166 | March 12, 2025 | |
| Split Beam at Intersections with Columns | 8 | 5992 | April 6, 2020 | |
| How paint structural elements | 0 | 419 | November 13, 2015 |
