For loop to get diffrent dimensions of rectangles with a fixed area
May I ask for your feedback?
I am starting with Python so I have to still learn a lot:)
I have my input:
  • a list with areas of rectangles
  • sliders with width and length.
I would like to create many rectangles with different dimensions that have the same areas as the areas in the list.
As output, I would like to get width and length which meets the condition W*L=rooms area
I wrote this code, but it doesn’t work…
May I ask you what I am doing wrong?
Many thanks for your support!
Best regards,
Julia
After the for you need to use a tab:
For …:
[Tab] if:
[Tab][tab]
[Tab]else:
[Tab][tab]
Im using my phone, can’t explain it better haha.
Btw the out is wrong too, the : needs between the " "
Hi @Julia_Ratajczak ,
Have you thought approaching this from the other way around?
Let’s say you want to create a rectangle with an area of 20 m2 but with random lengths.
You could simply create a shuffled list of x amount of items for the amount of rectangle you want.
Then from there simply do 20/x for each item to determine its width (assuming x is the height).
thank you for your reply. I applied all tabs, but it doesn’t work:(
What is the warning?
Hi Jacob,
there was a problemm with synatx - result_1 and result_2.
I changed it and it works now:)
It’s solved:)
Sorry, I realized that the script doesn’t work as I wish…the output was not what I intended…hahaha
I changed the approach using @Daan 's suggestion.
Now it’s working as I need:)
Thank you for all the support you have given me!!!
Hi Daan,
thank you for your suggestion.
Indeed, it works better:)
I put the solution at the end of the topic.
Many thanks!
Glad to hear that!
PS: You don’t really need a Python script here, you can just use the / node:
To reinforce your research in python (I am myself in the learning phase)
here are 2 scripts:
Script 1: Test
# Charger les bibliothèques DesignScript et Standard Python
import sys
# Les entrées effectuées dans ce noeud sont stockées sous forme de liste dans les variables IN.
Area_Room=IN[0]
Width=IN[1]
Lenght=IN[2]
Result=[]
# Placer votre code au-dessous de cette ligne
for i in Area_Room:
	if i == Width*Lenght:
		Result.append({"Surface good":i})
	else :
		Result.append("Change Width or Lenght")
# Affectez la sortie à la variable OUT.
OUT = Result
Script 2 with ratio:
import sys
Area=IN[0]
Ratio=IN[1]
Width=[]
Lenght=[]
for i in Area:
	L=round((i/Ratio)**0.5,3)
	W=round(L*Ratio,3)
	Lenght.append(L)
	Width.append(W)
OUT = {"Lenght":Lenght,"Width":Width}
Cordially
Christian
Hi Christian,
thank you so much:) I will check your approach. It’s great to have this knowledge exchange:)
Have a nice day!
BR,
Julia
Hi Christian,
the second script works great for me! Thank you for this approach!!!
Kind regards,
Julia
