So then, thinking with open mind on the matter, I find the idea of a plate filled with freshly slaughtered house flies, hairy caterpillars and dung beetles on a bed of crispy lettuce with side order of béarnaise sauce doesn’t set my mouth a water, tempting though it may sound to some it simply won’t work for my particular fads Paleo Eats Review and fancies no matter how glamorous the restaurant setting may be.Yet if professionally marketed dressed and displayed, I could possibly be convinced that Locusts and Grasshoppers were akin to a landward version of the humble prawn and thus may be tempted to a tester if found as Plat du Jour in some hospitable eating house.
http://purabellaantiagingcreamreview.com/paleo-eats-review/
Bees, served in honey on homemade bread or chocolate coated, sounds familiar as a local delicacy and as an insect perceived to be of the cleaner mini flyers variety could well tempt a hungry traveler to try, although the humble Bee probably does more good alive and propagating our plants than as a simple finger snack and so perhaps deserves to be treated as a special case and miss the edibles net if for this reason alone.But maggots and caterpillars in their common form, one has to admit to causing some distress if found on the plate between knife and fork.So perhaps more lateral thought may be needed in this instance, one shaft of light that comes to mind without creating negative issue is perhaps of such lowly creatures being factory farmed on scales as vast as the world desires, to then be ground down, mixed or beaten to paste to produce a high protein chicken feed, the resultant edible thus finally reaching the plate in the form of a Poulet Saute Chasseur of significantly generous proportions due to the supreme nutritional benefits that have been added by our wriggling brethren.
