Floors contain split lines
Hi all
I would like to find all Floors, that have a added Split Line to it, in Modify Sub Elements.
I have tried to find nodes in Dynamo, searched here, and around the web. :slight_smile:
No luck… Is this possible? I dont need to do anything else, than being able to add a comment to the floors, so no modification, just “are there a split lin” Yes/No"?
Thanks…
Hi @K.Kvistgaard i think about get the floors topsurface and if we have more than one…it could have a split and probably a slope as well, but these could be filtered out…but not sure if could work
another there probably could help is has slab be modified from clockwork ps…we can use floorpoints as well for test if it have been modifed…give empty if not
Hej Søren
I tried. Somehow I get 1 of the elements. I have 4 Floors in the test-project, and 2 of them with a added Split Line. But only one element in Dynamo. :frowning:
Hejsa Kristian :wink: nice with some compatriots here :wink: :wink: no not sure do you have a small rvt sample you could share ? but no guarantee…it work, it was just a fast idea i get so not tested in every situation ;
try with a math.round here
