Firefly
Not sure about STM32F401RE, but for it to work with the current Arduino IDE, the firmata needs to be modified as outlined here
Below is the altered version …
 Created by Andrew Payne and Jason Kelly Johnson
 Latest Update March 25th, 2015
 Copyright 2015 | All Rights Reserved
 This Firmata allows you to control an Arduino board from Rhino/Grasshopper/Firefly.
 Updates, Questions, Suggestions visit: http://www.fireflyexperiments.com
 1. Plug Arduino boards into your USB port; confirm that your Arduino's green power LED in on
 2. Select your specific Arduino Board and Serial Port (Tools > Board; Tools > Serial Port) *Take note of your Serial Port COM #
 3. Verify (play button) and Upload (upload button) this program to your Arduino, close the Arduino program
 4. then open ... Rhino/Grasshopper/Firefly
 Note: The Firefly Firmata sets the following pins to perform these functions:
 *****ON STANDARD BOARDS (ie. Uno, Diecimila, Duemilanove, Lillypad, Mini, etc.)*****
 ANALOG IN pins 0-5 are set to return values (from 0 to 1023) for analog sensors
 DIGITAL IN pins 2,4,7 will return 0's or 1's; for 3 potential digital sensors (buttons, switches, on/off, true/false, etc.)
 DIGITAL/ANALOG OUT pins 3,5,6,11 (marked with a ~) can be used to digitalWrite, analogWrite, or Servo.write depending on the input status of that Firefly pin
 DIGITAL OUT pins 8,9,10,12,13 can be used to digitalWrite, Servo.write, or analogWrite depending on the input status of that Firefly pin
 *****ON MEGA BOARDS (ie. ATMEGA1280, ATMEGA2560)*****
 ANALOG IN pins 0-15 will return values (from 0 to 1023) for 16 analog sensors
 DIGITAL IN pins 22-31 will return 0's or 1's; for digital sensors (buttons, switches, on/off, true/false, etc.)
 DIGITAL/ANALOG OUT pins 2-13 can be used to digitalWrite, analogWrite, or Servo.write depending on the input status of that Firefly pin
 DIGITAL OUT pins 32-53 can be used to digitalWrite, Servo.write, or analogWrite depending on the input status of that Firefly pin
 *****ON LEONARDO BOARDS*****
  *****ON DUE BOARDS (ie. SAM3X8E)*****
 ANALOG IN pins 0-11 will return values (from 0 to 4095) for 12 analog sensors
 DAC0 and DAC1 can be used to output an analog voltage on those pins (only available on DUE boards)
#include <Servo.h>            // attach Servo library (http://www.arduino.cc/playground/ComponentLib/Servo)
#include <pins_arduino.h>     // attach arduino pins header file to determine which board type is being used
#define BAUDRATE 115200       // Set the Baud Rate to an appropriate speed
#define BUFFSIZE 512          // buffer one command at a time
 * GLOBAL VARIABLES
char buffer[BUFFSIZE];        // declare buffer
uint8_t bufferidx = 0;        // a type of unsigned integer of length 8 bits
char *parseptr;
char buffidx;
int counter = 0;
int numcycles = 1000;
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)                                                // declare variables for STANDARD boards
  Servo Servo13, Servo12, Servo11, Servo10, Servo9, Servo8, Servo6, Servo5, Servo3;
  Servo SERVO_CONFIG[] = {Servo13, Servo12, Servo11, Servo10, Servo9, Servo8, Servo6, Servo5, Servo3};       // declare array of Servo objects
  int WRITE_PIN_CONFIG[] = {13,12,11,10,9,8,6,5,3};
  int READ_APIN_CONFIG[] = {0,1,2,3,4,5};
  int READ_DPIN_CONFIG[] = {2,4,7};
#endif
#if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega16U4__)                                               // declare variables for LEONARDO board
#endif
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)                        // declare variables for MEGA boards
  Servo Servo2, Servo3, Servo4, Servo5, Servo6, Servo7, Servo8, Servo9, Servo10, Servo11, Servo12, Servo13, Servo32, Servo33, Servo34, Servo35, Servo36, Servo37, Servo38, Servo39, Servo40, Servo41, Servo42, Servo43, Servo44, Servo45, Servo46, Servo47, Servo48, Servo49, Servo50, Servo51, Servo52, Servo53;
  Servo SERVO_CONFIG[] = {Servo2, Servo3, Servo4, Servo5, Servo6, Servo7, Servo8, Servo9, Servo10, Servo11, Servo12, Servo13, Servo32, Servo33, Servo34, Servo35, Servo36, Servo37, Servo38, Servo39, Servo40, Servo41, Servo42, Servo43, Servo44, Servo45, Servo46, Servo47, Servo48, Servo49, Servo50, Servo51, Servo52, Servo53};  // declare array of Servo objects
  int WRITE_PIN_CONFIG[] = {2,3,4,5,6,7,8,9,10,11,12,13,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53};
  int READ_APIN_CONFIG[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
  int READ_DPIN_CONFIG[] = {22,23,24,25,26,27,28,29,30,31};
#endif
#if defined(__SAM3X8E__)                 // declare variables for DUE boards
  Servo FDAC0, FDAC1, Servo2, Servo3, Servo4, Servo5, Servo6, Servo7, Servo8, Servo9, Servo10, Servo11, Servo12, Servo13, Servo32, Servo33, Servo34, Servo35, Servo36, Servo37, Servo38, Servo39, Servo40, Servo41, Servo42, Servo43, Servo44, Servo45, Servo46, Servo47, Servo48, Servo49, Servo50, Servo51, Servo52, Servo53;
  Servo SERVO_CONFIG[] = {FDAC0, FDAC1, Servo2, Servo3, Servo4, Servo5, Servo6, Servo7, Servo8, Servo9, Servo10, Servo11, Servo12, Servo13, Servo32, Servo33, Servo34, Servo35, Servo36, Servo37, Servo38, Servo39, Servo40, Servo41, Servo42, Servo43, Servo44, Servo45, Servo46, Servo47, Servo48, Servo49, Servo50, Servo51, Servo52, Servo53};  // declare array of Servo objects
  int WRITE_PIN_CONFIG[] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,32,33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48,49,50,51,52,53}; //Note: first two values correspond to the DAC pins
  int READ_APIN_CONFIG[] = {0,1,2,3,4,5,6,7,8,9,10,11};
#endif
 * SETUP() This code runs once
void setup()
  Init();                       //set initial pinmodes
  Serial.begin(BAUDRATE);       // Start Serial communication
  #if defined(__SAM3X8E__)      //if the connected board is an Arduino DUE
    analogReadResolution(12);   //Set the analog read resolution to 12 bits (acceptable values between 1-32 bits).  This is only for DUE boards
    analogWriteResolution(12);  // Set the analog write resolution to 12 bits (acceptable values between 1-32 bits).  This is only for DUE boards
  #endif
 * LOOP() This code loops
void loop()
  if(Serial){
    ReadSerial();                       // read and parse string from serial port and write to pins
    if (counter >= numcycles){          // Wait every nth loop
      ReadInputs();                     // get input data and print data to the serial port
      counter = 0;                      // reset the counter
    counter ++;                         // increment the writecounter
 * FUNCTIONS()
* Initializes the digital pins which will be used as inputs
void Init(){
  int len = sizeof(READ_DPIN_CONFIG)/sizeof(READ_DPIN_CONFIG[0]); //get the size of the array
  for(int i = 0; i < len; i++){
    pinMode(READ_DPIN_CONFIG[i], INPUT);
* Reads the incoming ADC or digital values from the corresponding analog and digital input
* pins and prints the value to the serial port as a formatted commma separated string
void ReadInputs(){
  int len = sizeof(READ_APIN_CONFIG)/sizeof(READ_APIN_CONFIG[0]); //get the size of the array
    int val = analogRead(READ_APIN_CONFIG[i]);  //read value from analog pins
    Serial.print(val); Serial.print(",");
    int val = digitalRead(READ_DPIN_CONFIG[i]); //read value from digital pins
  Serial.println("eol");  //end of line marker
* Retrieve the latest incoming serial value and split the string at the comma delimeter.
* When a comma is found, the value is offloaded to a temporary variable and written
* to the corresponding digital pin.
void ReadSerial(){
  char c;    // holds one character from the serial port
  if (Serial.available()) {
    c = Serial.read();         // read one character
    buffer[bufferidx] = c;     // add to buffer
    if (c == '\n') {
      buffer[bufferidx+1] = 0; // terminate it
      parseptr = buffer;       // offload the buffer into temp variable
      int len = sizeof(WRITE_PIN_CONFIG)/sizeof(WRITE_PIN_CONFIG[0]); //get the size of the array
        //parse all incoming values and assign them to the appropriate variable
        int val = parsedecimal(parseptr);       // parse the incoming number
        if(i != len - 1) parseptr = strchr(parseptr, ',')+1;   // move past the ","
        WriteToPin(WRITE_PIN_CONFIG[i], val, SERVO_CONFIG[i]);         //send value out to pin on arduino board
      bufferidx = 0;                             // reset the buffer for the next read
      return;                                    // return so that we don't trigger the index increment below
    }                                            // didn't get newline, need to read more from the buffer
    bufferidx++;                                 // increment the index for the next character
    if (bufferidx == BUFFSIZE-1) bufferidx = 0;  // if we get to the end of the buffer reset for safety
* Send the incoming value to the appropriate pin using pre-defined logic (ie. digital, analog, or servo)
void WriteToPin(int _pin, int _value, Servo _servo){
  if (_value >= 10000 && _value < 20000)            // check if value should be used for Digital Write (HIGH/LOW)
    if (_servo.attached()) _servo.detach();         // detach servo is one is attached to pin
    pinMode(_pin, OUTPUT);
    _value -= 10000;                                // subtract 10,000 from the value sent from Grasshopper
    if (_value == 1) digitalWrite(_pin, HIGH);
    else digitalWrite(_pin, LOW);
  else if (_value >= 20000 && _value < 30000)       // check if value should be used for Analog Write (0-255)
    _value -= 20000;                                // subtract 20,000 from the value sent from Grasshopper
    analogWrite(_pin, _value);
  else if (_value >= 30000 && _value < 40000)       // check if value should be used for Servo Write (0-180)
    _value -= 30000;                                // subtract 30,000 from the value sent from Grasshopper
    if (!_servo.attached())_servo.attach(_pin);     // attaches a Servo to the PWM pin (180 degree standard servos)
    _servo.write(_value);
  else if (_value >= 40000 && _value < 50000)       // check if value should be used for Analog Write (0-4096) for DACs
    _value -= 40000;                                // subtract 40,000 from the value sent from Grasshopper
    WriteToDAC(_pin, _value);
* Parse a string value as a decimal
uint32_t parsedecimal(char *str){
  uint32_t d = 0;
  while (str[0] != 0) {
    if ((str[0] > '50') || (str[0] < '0'))
      return d;
    d *= 10;
    d += str[0] - '0';
    str++;
  return d;
* Send the incoming value to the appropriate DAC for DUE boards.
* Note: analogWrite resolution (default is 12 bits) is defined in the Setup function.
  void WriteToDAC(int _pin, int _value){
    if(_pin == 0) analogWrite(DAC0, _value);
    else if (_pin == 1) analogWrite(DAC1, _value);
    #endif
