Find Python code “FilledRegion.ByCurves in ActiveView”
I’m trying to reproduce this script but I do not know where to find the Python code “FilledRegion.ByCurves in ActiveView”.
Thank you
JF
It’s a @Kulkul’s script :
# From Kulkul
# Import RevitAPI
clr.AddReference('RevitAPI')
# Import Element wrapper extension methods
# Import geometry conversion extension methods
#The inputs to this node will be stored as a list in the IN variable.
doc =  DocumentManager.Instance.CurrentDBDocument
listCurves = IN[0]
listFilledRegionName = IN[1]
viewId = doc.ActiveView.Id
listFilledRegion = []
for filledRegionName in listFilledRegionName:
	for fr in FilteredElementCollector(doc).OfClass(FilledRegionType):
		if Element.Name.GetValue(fr) == filledRegionName:
			listFilledRegion.append(fr)
regions = []
for curve,filledRegion in zip(listCurves, listFilledRegion):
	curveLoopList = []
	floorCurves = CurveLoop()
	for line in curve:
		floorCurves.Append(line.ToRevitType())
	curveLoopList.Add(floorCurves)
	coloredRegion = FilledRegion.Create(doc, filledRegion.Id, viewId, curveLoopList)
	regions.append(coloredRegion.ToDSType(False))
OUT = regions
Hello Alban,
  thank you very much for your help.
JF
