Greeting. I am working on a intersection task between several surface and MEP.
I am able to change to MEP into line by using Element Location. But later I found it seems there is no node for intersection between surface and lines. What I can only find is GeometryVSGeometry and GeometryVSCurve.
What I can figure out first is to change the surface to solid by using surface.thickness node. But later I find it causes error as some of the case are falsely detected as clashed.
So what I would like to ask: Is there any way to find intersection between Surface and Lines?
