I’m new to Dynamo and am not certain why this is happening. This is a fairly simple find and replace graph. Why does the equal(==) node give a false result to everything on the list even though they are matching? Are there any additional errors that need to be corrected for the graph to work smoothly?
I apologize if this has posted and answered previously.
Thanks in advance.
Looks like the value of the note is
"Test
And you are looking for just
"Test"
Note the lack of a return/new line.
I thought that might be the case and checked it. There is no new line in the text notes that were written.
I even tried to match the String node(the one that inputs to y on equal node) to
"Test
The equal node still returns false.
There may be something else we aren’t seeing. Test tab return. Or test return tab. Or a dozen zero width space characters in there.
- Clockwork package has a node ‘Clipboard.SendTo’.
- Get the first item from your TextNote.Text node, and pass that onto the Clipboard.SendTo node.
- Paste the results into the string node feeding into the Y input of the == node.
- Post the image showing the results.
TextNote.Text seems to be the culprit- it adds in an extra CRLF at the end of the text
However, it is fairly easy to work around
This solution works. Thank you very much.
