Find and Add using Dynamo
I’m trying to come up with dynamo scripts that looks at the Parameter (Material name) for Parts and then add a code in a different Parameter based on the (Material name).
Please see the Image below for what I have done and the error I’m getting
Thank you for the help
My guess is that this parameter needs a string. Which means this will require converting the material element into text, such as via an Element.name node.
Jacob - Thank you for the help.
I tested the (Element.name) the script is working now but it’s not replacing the name from (5.5 Metal Stud) to (9010) it’s just adding (5.5 Metal Stud).
Please see below.
Revit_Test 2
Material.Name should go before the code block, not after.
