Hi, need your help finding the pipes that are Not connected so I can determine if it is a tee-fitting or an elbow to vertical pipe.
As can be seen in the pic. I’ve got 57 horizontal pipes and 27 elbows are created, now I need to find those pipes that not has an elbow connected and try to connect to vertical pipes or even make a tee-fitting.
But I cant get the result I need to further process.
Feel free to comment on the approach
@BIM_Mrbrango ,
it seems to be deeper in the element…
i am just able to collect the stuff
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Plumbing import *
from Autodesk.Revit.DB.Mechanical import *
clr.AddReference('System')
#functions
def tolist(x):
if hasattr(x,'__iter__'): return x
else: return [x]
#collector
collector = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_PipeCurves)
all_elements = collector.WhereElementIsNotElementType().ToElements()
elements = UnwrapElement(tolist(all_elements))
output = []
for i in elements:
output.append(i.IsConnected)
OUT = output
when you look via LOOKupTable, it is in the connector-manager
Online Documentation for Autodesk's Revit API: 2015, 2016, 2017, 2017.1, 2018
KR
Andreas
Hi Andreas,
Thanks for mentioning IsConnected, I think I can use that insted of element.id.
I’ll get back to you!
