Dears,
I’m trying to filter a list with the values from another list, getting at the end a boolean list.
In other words, coming from the list generated by “Element.GetParameterValueByName”, I would like to crosscheck all values with the “CodeBlock” list what I’ve made. Getting at the the, a boolean list with “true” or “false” keys. In order to use it on a FilterByBoolMask node, and to get a filetered list with the previous elements.
Thanks in advance
What about a List.Contains node?
Doesn’t work properly.
I sure headache comes cause both lists don’t follow ther same values order.
Thanks,
But, if the input list comes from a “messy” values list, the code block launchs all falses. For Example:
The item “42” on the list has the no. 9 which is equal than item “2” of Codeblock, no. 9 as well. Then, on the boolean list (the last one), the result sould be “True” instead of “False” that I get.
My fault.
For now, solved.
I’m gonna try on the original dynamo.
As I understand, you want to split the elements of list A, according to List B:
- if elements A are in list B > True
- if elements A are not in list B > False
Am I correct?
If yes, just do it exactly as I posted it, remember to use LONGEST LACING (look at the right-bottom corner, you have now AUTO).
In the screenshot you posted, I expect the following result:
True,False,True,False,False,True,False,True
which is not exactly what you have
I think that you should look again at @lucamanzoni’s solution.
Yours only gives a true to 0 it should also do so for 5 & 6?
I think you need to copy his longest lacing and levels… As @erfajo suggested.
@lucamanzoni’s
@FernandoFCC’s
Hope that helps…
Mark
Thank both very much, I was solved using longer lacing.
