I have put together a definition that allows me to set the Workset for different elements in my Revit model.
I would like to be ably to filter my elements by “Structural Material” however, for some reason I cannot filter my elements using this parameter. As you can see on the image, currently I am having to choose a category and the only problem with that is that under structural framing for example, you can have steel, concrete or timbre beams thus you may not want assign lets say, steel Workset to all structural framing elements.
I created a similar one! the only thing I’d say is that if you filter by structural material, you need to make all your elements have the right “structural material” assigned. I know that some are set “by category” which is annoying!
