Filled Region's edges is not updated after changing Instance Parameter: Subcategory (Line Style, Graphic Style) by Dynamo
Greetings, community,
I wrote a Dynamo script(ver 2.12) that can change the line style of picked edges of a filled region(see attached). In short, it is similar to the Linework tool found in the Modify tab > View panel, but it can be applied to filled regions.
The problem is that after running the script, the line style of the selected edges does not update immediately. You have to hit “Edit Boundary” for that filled region to see the changes. Is there any way to have Revit update instantly?
LineworkFilledRegion.dyn (44.2 KB)
