Guys,
I need help with changing filled region boundary line types from “Thin” to “Invisible Lines” on thousands of filled regions that are used in my detail library central file.
I cannot find any nodes changing the selected line types. Could you advise?
Here’s how far I got.
For whatever reason, it only changed 1 of the filled region’s boundary and I am wondering why.
Try setting the list level of filledRegion to @L1.
How do you do that? Please teach me!
ARCH - Change All Filled Region Boundary Type.dyn (6.3 KB)
This is the file.
Basically, I want all filled regions’ boundary lines to be changed to the one that I assign, such as “invisible line” in thousands of drafting views.
However, looks like the node is broken.
I’d recommend working through the Dynamo Primer to get introduced to all the basics. This will make things much easier. In this case you could also just change the lacing to Longest, but List Levels are generally better practice.
I gave up Nick. Do you have any idea to fix this?
What did you try? The fix is to use list levels or lacing. You can search the forum or use the Dynamo Primer to learn more about those methods if you’re unfamiliar with them. If you have a specific question about either one then you can ask that.
