Fields in Block Attributes
I have a block with attributes but those attributes have fields in them.
reading up here for what to do with attributes: https://forum.dynamobim.com/t/blockreference-create-removes-block-attributes/44306/16
If I set the attribute then the field is gone. Does anyone have an idea how to preserve the fields?
SharedCoordinatesBlock.dwg (912.5 KB)
block: projectbasepoint2022
purpose of the block: Place it somewhere, regen and you see it’s coordinates which can then be easily read and checked when linking the file in Revit.
PlaceBlockByCoordinates.dyn (19.1 KB)
Hi @Daniel.Gijsbers,
I think that issue is still present. You can try something like this to ATTSYNC the block after placing it.
Thank you I’ll give it a try
