'FamilyInstance' object has no attribute 'Parameters' on CPython3
Hello Dynamaniacs!
I’m migrating my Scripts from IronPython2 to CPython3 and I have this problem:
The following code works perfectly on IronPython2, but it throws this error when I run it under CPython 3
AttributeError : ‘FamilyInstance’ object has no attribute ‘Parameters’ [’ File “”, line 30, in \n’]
Does anybody have an Idea, what the solution could be?
clr.AddReference("ProtoGeometry")
clr.AddReference("RevitAPI")
roomgroups = UnwrapElement(IN[1])
tops = UnwrapElement(IN[2])
niches = IN[0]
output = []
tosum = []
for ix, roomgroup in enumerate(roomgroups):
	top_pars = tops[ix].Parameters
	for ix2, room in enumerate(roomgroup):
		area = room.LookupParameter("Fläche").AsDouble()
		topo_name = room.LookupParameter("Topo_RaumName").AsString()
		if topo_name != "Balkon" \
		or topo_name != "Garten" \
		or topo_name != "Loggia" \
		or topo_name != "Terrasse":
			tosum.append(area)
		for par in top_pars:
			try:
				if topo_name in par.Definition.Name:
					par.Set(area)
			except:
				pass
	par_area = tops[ix].LookupParameter("FP_Top_Fläche")
	par_area.Set(sum(tosum))
	tosum = []
OUT = output
it’s strange :flushed:, it looks like PythonNet doesn’t always manage to go up the inheritance tree (methods and properties)
this is the 2nd time I see this problem
Hi @CarlosCMB
I don’t see the same error for me in CPython3 :thinking:
Possible to share relevant rvt and dyn file?
@CarlosCMB
What’s your config?
  • Windows version?
  • Revit version?,
  • Dynamo version?
  • run on Virtual machine?
Feels like the imports not being setup is impacting this…
Edit: Curious what options are exposed via dir(elem) both with and without the imports; somehow it feels like the answer will be in that set.
