FamilyInstance.FlipFacingOrientation doesnt seem to work
i want to flip multiple elements at once
i saw this node form clockwork i think i does what i need but it says success but nothing changes
post a copy of the family perhaps?
IC_CCTV_Dome Camera.rfa (3.2 MB)
ty for reply
Thats the family. my question is does that node do the function i think it does or iam understanding it wrong as iam new to dynamo
fam_inst_flip_workplane.dyn (4.6 KB) Try this.
Nope. I think it flips facing orientation as the node name suggests while the icon is flipping workplane.
Flipping with spacebar isnt fast enough?
:rofl:
but if you think about it, when op pairs this with some complex prefiltering to grab that list of elements, it might just outperform mouse & keyboards speed wise.
Revit has three flipping planes - WorkPlane (XY, Top/Bottom, Horizontal), Handing (YZ, Left/Right, Vertical perpendicular to Front) and Facing (XZ, Front/Back, Vertical perpendicular to side)
Archilab and Clockwork have nodes to flip handing and facing, however this isn’t going to cut it for your task
Here is a python script which can flip the WorkPlane - note this will toggle the WorkPlane flipping between True and False
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import FamilyInstance
def flip_workplane(item):
    if isinstance(item, FamilyInstance) and item.CanFlipWorkPlane:
        item.IsWorkPlaneFlipped = not item.IsWorkPlaneFlipped  # Toggle
        return item
    return f"WorkPlane cannot be flipped for this instance {item.Id}"
def to_list(items):
    if isinstance(items, list):
        return UnwrapElement(items)
    return [UnwrapElement(items)]
OUT = map(flip_workplane, to_list(IN[0]))
