FamilyInstance.ByPoint node issues
I’ve been trying to troubleshoot a script and have identified the ‘FamilyInstance.ByPoint’ built-in node as the problem.
To prove what I’d been seeing, I created a basic script to test things and have managed to replicate the issues that I’m having.
If I use the node to create a new family instance, then it works just fine. However, when I then move the new instance of the family to another position and then re-run the script, in theory creating a new instance, then rather than creating another instance of the family, it moves the first one back to the original point…
The same thing happens using the ‘FamilyInstance.ByPointAndLevel’ built-in node and also through a code block using FamilyInstance.ByCoordiantes and .ByPoint, presumably, as they replicate the nodes?
I do not know how to explain why but here is some help:
http://dynamobim.org/forums/topic/custom-node-behavior/
I guess you already found out that if you cancel some nodes and position them again ( or even close and re-open the script) it should work as you wish.
Close and re-open the DYN
@Andrew_Casey I got this bad boy fixed :slight_smile:
Here is the code:
doc =  DocumentManager.Instance.CurrentDBDocument
clr.AddReference("RevitAPI")
def ptslist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
famType = UnwrapElement(IN[0])
pts = ptslist(IN[1])
lvl = UnwrapElement(IN[2])
elems = []
for pt in pts:
	elems.append(doc.Create.NewFamilyInstance(pt.ToRevitType(True), famType, lvl, Structure.StructuralType.NonStructural))
OUT = elems
