Family Quick Check For Corrupt Families
Hi, I’m auditing a list of families. I am using the “Family Quick Check” tool from pyRevit. It does a pretty good job. The challenge is the data that is generated is painful to manage as there is no save to Excel/CSV option for the families with Errors.
I reviewed the original “FamilyQuickcheck_script.py” file from the pyRevit Master folder but my knowledge is not good enough to implement it in Dynamo yet.
Would be great if anyone could help to implement similar thing from dynamo.
Thanks in Advance.
Hi @Sujan ,
Could you share some screenshots/ code from the pyRevit code you described?
I have attached the original “.py” file here.
FamilyQuickcheck_script.py (3.2 KB)
Original Author of the code is Fredric Beaupere
bump
Hello
here is an example with IFailuresPreprocessor, to be improved if necessary
import sys
import System
from System.Collections.Generic import List, IList, Dictionary
clr.AddReference('RevitAPI')
from Autodesk.Revit.UI.Events import ViewActivatedEventArgs, ViewActivatingEventArgs, DialogBoxShowingEventArgs
projDoc = DocumentManager.Instance.CurrentDBDocument
app = DocumentManager.Instance.CurrentUIApplication.Application
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
class FailureAdvancedHandler(IFailuresPreprocessor):
	# create a dictionnary to store families with warnings
	dict_Warning = Dictionary[System.String, List[System.String]]()
	def __init__(self, famDoc):
		self._famDoc = famDoc
	def PreprocessFailures(self, failuresAccessor):
		failMessages = failuresAccessor.GetFailureMessages()
		if failMessages.Count == 0:
			return FailureProcessingResult.Continue
		transName = failuresAccessor.GetTransactionName()
		try:
			self.__class__.dict_Warning.Add(self._famDoc.Title, List[System.String]([m.GetDescriptionText() for m in failMessages]))
			# if alert is an warn remove it
			if failuresAccessor.GetSeverity() == FailureSeverity.Warning:
				for currentMessage in failMessages:
					failuresAccessor.DeleteWarning(currentMessage)
			# if alert is an error resolve it (by delete elements or by split group etc...)
			elif failuresAccessor.GetSeverity() == FailureSeverity.Error:
					failuresAccessor.ResolveFailure(currentMessage)
				return FailureProcessingResult.ProceedWithCommit
				pass
		except Exception as e:
			import traceback
			errors.append(traceback.format_exc())
toList = lambda x : x if hasattr(x, '__iter__') and not isinstance(x, (str, System.String)) else [x]
lstfamiliesPath = toList(IN[0])
errors = []
dict_warnings = None
dict_corrupted = Dictionary[System.String, System.String]()
for familyPath in lstfamiliesPath:
	try:
		famDoc = app.OpenDocumentFile(familyPath)
		TransactionManager.Instance.ForceCloseTransaction()
		t = Transaction(famDoc, 'Test')
		t.Start()
		failureOptions = t.GetFailureHandlingOptions()
		handler = FailureAdvancedHandler(famDoc)
		failureOptions.SetFailuresPreprocessor(handler)
		t.SetFailureHandlingOptions(failureOptions)
		if famDoc.IsFamilyDocument:
			famManager = famDoc.FamilyManager
			for familyType in famManager.Types:
				famManager.CurrentType = familyType
				famDoc.Regenerate()
		import traceback
		error = traceback.format_exc()
		fileName = System.IO.Path.GetFileNameWithoutExtension(familyPath)
		dict_corrupted.Add(fileName, error)
		t.Commit()
		t.Dispose()
		famDoc.Close(False)
		famDoc.Dispose()
dict_warnings = FailureAdvancedHandler.dict_Warning
OUT = dict_corrupted, dict_warnings
