Hi
Does any body know if theres a Node out there capable of extracting package names if nodes from the package is used in the .dyn?
Thanks in advance
Jesper
Hi
Thanks in advance
Jesper
Hi Erik
A picture is worth a thousand words, below picture better explains what i was looking for.
Â
You can definitely do it for custom nodes (meaning *.dyf files) but I don’t think it’s possible for zero touch nodes. The below is something I cobbled up during lunch break:
This is an extremely inefficient method because it involves managing huge amounts of strings. It’d probably be a lot better if you can replace some of the string operations with proper XML parsing.
Edit:
Here’s a slightly optimized version with Lunchbox’s “DataSets.GetXMLNode” node:
Briliant Dimitar! this is exact the data extraction I was looking for.
Thanks!!
Â
Hi All
The final result with room for improvement like always
One step closer to automatically create a table of content for my .dyn library.
