Hi all,
I’ve managed to write a python script to extract level information for a couple of categories (Structural Framing, Structural Columns). However I’m wondering if this is the right/lean way to do it using multiple try/except statements as these categories are based on different built-in parameters. Please can you give me some pointer? Thanks, much appreciated in advance!
clr.AddReference('RevitAPI')
clr.AddReference('System')
#Assign Document
#Preparing input
elements = UnwrapElement(IN[0])
output = [ ]
#Transaction
for e in elements:
elem = []
#Levels
try:
Level = e.get_Parameter(BuiltInParameter.LEVEL_PARAM).AsValueString()
except:
try:
Level = e.get_Parameter(BuiltInParameter.INSTANCE_REFERENCE_LEVEL_PARAM).AsValueString()
except:
try:
Level = e.get_Parameter(BuiltInParameter.FAMILY_BASE_LEVEL_PARAM).AsValueString()
except:
try:
Level = e.get_Parameter(BuiltInParameter.FAMILY_LEVEL_PARAM).AsValueString()
except:
Level = "n/a"
#Output
elem.append(Level)
output.append(elem)
OUT = output
Well - first - from what I see, you don’t need a transaction. A transaction is only needed when you are modifying the Revit data. You are just collecting information.
A better outline for the code would be to know what you are looking for based on the item type (Probably a particular built-in category.)
for e in elements:
if e is widgetA:
do stuff
elif e is widgetB:
do other stuff
elif e is widgetC:
etc.
Try except may get you what you want, but it can be difficult to debug and is a bit heavy handed.
you can study element.level from clockwork
def GetLevel(item):
val = None
if hasattr(item, "LevelId"):
val = item.Document.GetElement(item.LevelId)
if val: return val
if hasattr(item, "Level"):
val = item.Level
if val: return val
if hasattr(item, "GenLevel"):
val = item.GenLevel
if val: return val
if (item.GetType().ToString() in ("Autodesk.Revit.DB.Architecture.StairsRun", "Autodesk.Revit.DB.Architecture.StairsLanding")):
item = item.GetStairs()
if (item.GetType().ToString() == "Autodesk.Revit.DB.Architecture.Stairs"):
try: return item.Document.GetElement(item.get_Parameter(BuiltInParameter.STAIRS_BASE_LEVEL_PARAM).AsElementId())
except: pass
if (item.GetType().ToString() == "Autodesk.Revit.DB.ExtrusionRoof"):
try: return item.Document.GetElement(item.get_Parameter(BuiltInParameter.ROOF_CONSTRAINT_LEVEL_PARAM).AsElementId())
except: pass
if not val:
try: return item.Document.GetElement(item.get_Parameter(BuiltInParameter.INSTANCE_REFERENCE_LEVEL_PARAM).AsElementId())
except:
try: return item.Document.GetElement(item.get_Parameter(BuiltInParameter.INSTANCE_SCHEDULE_ONLY_LEVEL_PARAM).AsElementId())
except:
try: return item.Document.GetElement(item.get_Parameter(BuiltInParameter.SCHEDULE_LEVEL_PARAM).AsElementId())
except: return None
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetLevel(x) for x in items]
else: OUT = GetLevel(items)
Great, this is the exact example that i need! Thanks for the reminder
FYI, there is an Element Level node in the Genius Loci package that works with all the categories.
Many thanks for your response. I’m trying to learn python so just try to write some simple scripts.
