I’m looking for a way to extract a Family’s parameter values that are derived from the lookup table linked to the Family. Is there a way to access the lookup table data through Dynamo OR preferably extract the parameter value that changes by the lookup table?
For example, a valve Family’s length is set by a lookup table, which uses the pipe nominal diameter as input. So if pipe dia=400 -> valve length=216, pipe dia=500 -> valve length 285 or something.
Right now I can only get the value only if the Family instance is created inside Revit. But I want to know the value without creating a Family element. The Family and Family type will be given as input.
Any advice would help!
Thanks.
