Exporting only the walls and roof sections from revit
Hi, I was looking at exporting only the walls and roof of a Revit project file to DWG.
The usual export of sections from a project are exporting broken or incomplete wall lines. Is there anyway to make sure that all the wall profiles are being create in the Exported ca file.
Thanks in advance.
@tkmahesh1 ,
actually i can`t follow your question completly… sounds like a Revit Issue.
1.) i would set a view with your disered categories
2.) you can export as .dwg
a.) export just a 3D View
b.) export 3D View placed on a sheet (so you can flatten it)
KR
Andreas
Thanks @Draxl_Andreas
Exporting a 3d view and then flattening it worked. :smiley:
Regards,
TK
