Hello friends,
I 'm trying to export a list of Dynamo data to a file with XML extension. I found only this node to do , but does not recognize well what I want to do.
Does anyone know how to do it ?
Thx in advance!!!
Hello friends,
Thx in advance!!!
Hi, I guess there should have been a slight change to the input names on the serializer node from Luncbox, because it expects a dataset which again is built up with datatables. I’m not an expert in XML parsing but have a look at it and let me know if it helps! If you can share more of your definition maybe we can help you further.
[quote=“r.gomez39, post:1, topic:4424”]
I 'm trying to export a list of Dynamo data to a file with XML extension. I found only this node to do , but does not recognize well what I want to do.Does anyone know how to do it ?
[/quote]FilePath wants a file path not a string
XML wants a string containing XML
This kind of thing:
Thank you very much in advance for both, Truevis and Jostein.
The process now goes well!
I think it’s interesting to export data from Revit families to an XML extension.
Truevis, in the input “FilePath” connect “Path” How can you say , but also can connect to a Code Block or string if you add in the end the XML extension.
Thank you again!
Hi!
Thanks for explaining the concept. I have a question. How do you attach attribute values to attributes?
Say I wanted to edit the name=“Austria” to name=“Denmark” in the example below, or add a completely new attribute i.e climate=“Moderate”;
<gdppc>141100</gdppc> <neighbor name="Austria" direction="E"/>
How would I do that following your Dynamo example?
Thanks,
Adam
