Not sure what went wrong in the script below if anyone can help? I am not able to export either csv or xlsx for schedule.? Any suggestion? thanks all
@kuso26 What error is the node outputting?
It said the operational failed on the node. Attach is the dyn file for your review if possible?
Exportcsv.dyn (14.7 KB)
What package is view.getbytype?
archi.lab package I believe.
@kuso26 Create the directory. It can’t create a file if the file path doesn’t exist. Reopen it after the directory is created in case it keeps a memory of the file path not being valid.
Now it works:
If this solves your issue, please mark it as solution.
Yup, that definite solve the issue. I originally though it will create the folder if not exist.
Thank you so much.
